I am about to hook up a new oil tank to my boiler and just want someone to say if i am going about things the right way.
Gate valve connected directly to the oil tank using ptfe around threaded connection.
Guage connected directly to the gate valve using ptfe around threaded connection.
Compression fitting joining 10mm sheathed copper pipe to gauage.
Compression fitting joining 10mm pipe to oil filter.
Compression fitting joining oil filter to existing 10mm pipe leading to boiler.
Does that sound about right - just curious about the order of things - ie does the filter come after the guage or before it.
Thanks.
Thanks.
