Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
i installed a new secondhand cookers oven( electric )it had a bit of condensation on it it has never been used it keeps tripping out the electric the bottom element works outside the oven but it trips when put back in side can this be repaired thanks for any help
Put the element that does work on and leave it to warm up. This will dry out the condensation and you should find that once this has happened the oven works fine.
There is a similar post on here sometime recent with someone having the same problem.
