New room thermostat advice
9 Feb 2009
London
Hello all,
Would someone be able to recommend a good replacement for a Proscon Type PBC10 room thermostat ?
We are just after a basic one with only a dial like the current one.
Have taken the cover off and there are 5 terminals to which wires can go (but only 4 are used) and the ones that are connected are as follows;
Far left = earth yellow\green wire
Then the next terminal has no wires (terminal marked as Cooling)
The next is the Red wire (terminal marked as Heating)
Then the Blue wire (terminal marked as Neutral)
Then the Yellow wire (terminal marked as Line)
I would ideally like to go for one to which the same number of wires above can be connected so that its an easy swap. Are the wire colours standard ?
Thankyou
Yes.
Here we go:
I'd use the word conventional, rather than standard, but yours fit the convention, so you won't have any trouble.
