Hello all, I have searched right the previous posts on this subject but i cannot seem to find the correct answer, so here goes.
I have recently renewed my livng & dining room light roses, following the sequence, turn off mains, identify switch wire and main feed in, this leaves the final cable as being the link to the next light. Next connect wires as per instructions supplied. Switch on mains & test light before moving to next light.
All seemed ok until I got to renewing the kitchen rose.
This has some kind of connection to an outhouse light which seems to be part of the problem.
The light is switched on by a double switch, one switch powering the interior light & one for the outside.
Using the same proceedure as above I identified the appropriate cables, connected them up and tested. The light comes on but is slightly dimmer than normal using a 100w bulb. Changed the bulb to 150w and the light just glowed orange.
I then noticed the light in the outhouse is on but only just glowing, so I disconnected at the switch and taped up the wires, just to see if it made any difference but the light in the outhouse stayed the same.
If it helps this is a 1950s ex council house, the wire is solid core (red/Black) twin + earth and within the original rose, which was held together by 1/4 inch of bloody artex, there was the usual three main cables and a rubber covered 2 core (silver strands) cable (i have not connected this cable to anything as I cannot see an use for it.
ANY help with this would be greatly appreciated
