Hello,
I am in the process of converting a kitchen into a dining room. I'd like to add a wall light, approximately where the old, now unused, 30 amp cooker supply runs. I was hoping I could use the existing wiring for the light, and change the MCB in the consumer unit to a more suitable (5 amp?) one. I'm assuming there's no problem in doing this? Other than someone in future being very surprised to see such a massive cable running one puny light!
Regarding chasing out the wall (it's brick/plaster) for cable runs, I'd like the switch to be on an adjacent wall. Would it be OK (in terms of accepted practice) to chase out a vertical run a foot or so down from the light, then horizontally, around the corner to the switch?
On this hastily sketched image, the blue is the existing 30amp supply cable, the green would be a new cable to take it across (about 6 inches) to the light, and the red is a new switched loop to the switch:
The whole room will be replastered in a couple of weeks.
Any thoughts/opinions on this would be greatly appreciated!
Thanks,
Paul
Thanks,
Paul
