No central heating, but hot water is OK
hat
14 Dec 2005
My Central Heating suddenly stopped working. However, the hot water is fine.
When I turn the Hot Water ON through the Programmer / Timer (say constant), the boiler immediately fires.
However, when I do the same for Central Heating, it doesn’t fire the Boiler (the Pilot is ON).
I have replaced the Programmer / Timer, but it doesn’t help.
Can the problem be with the Room Thermostat (it makes the clicking sound though, when turned) or is it the Boiler ?
24 Jul 2003
London
We need to know more about your system. Motorised valves?
hat
14 Dec 2005
I think so. There is a 3 way valve near the hot water storage tank housing.
But the boiler doesn't even fire. It's a Glowwarm one.
14 Dec 2005
Yorkshire
I think your syncron motor in the valve has gone ( easy fixed) or te swiching in the valve has gone (new valve).
If your the Hat of Sislden fame ill pop down and sort it for you!!
hat
14 Dec 2005
I'm down South (far from Yorkshire) !
The Motor (Grundfos) is less than a year old, so it could be the Valve.
But shouldn't the Boiler fire (burner at full blow) and then overheat or make noise, etc ? The boiler doesn't fire at all. However, it works fine for Hot Water.
14 Dec 2005
Yorkshire
Its the motor in your valve...........its not winding the valve over and making the swtiches on the Central Heating side. What make of Valve is it you have?
hat
14 Dec 2005
I am not sure. Have to check. It's a silver coloured one.
So you mean it's not the main motor (the big Grundfos one), but the actual Valve (where is the second motor) ?
14 Dec 2005
Yorkshire
If ist silver is likley to be a honeywell one. it contains a moteor called a syncron motor. Its that that is suspect. Its an easy job but a bit of a faff if you dont know what your doing.
hat
14 Dec 2005
I'm OK about Electrical connections, but if it involves plumbing as well (and turning off things), should I get someone to do it for me. What do you say ?
