I am helping my son renovate his first house. The Central heating boiler is a Baxi Solo (not combi) but the system does not appear to have a traditional Feed and expansion tank. The radiator in the bathroom has a feed into the "flow" pipe from a wall mounted plastic "ornamental tank"(about 3 litre capacity) which has to be topped up manually !! - there appears to be no expansion pipework at all! - Since we are refurbing the bathroom we want to replace the radiator / remove this feed tank - The hot water cylinder is an indirect one - could we simply tap into the flow and return pipework as they enter/leave the cylinder and run pipework from here to a conventional feed and expansion tank adjacent to the cold water storage tank in the loft above ? (I presume expansion pipe into Feed and feed pipe into return) PS The central heating system radiators do operate on a two pipe system.
Have I oversimplified the solution ? or could we proceed on this basis?
Plan to have heating replaced eventually but he's out of cash for a while
