No Hot water coming from shower
6 Mar 2009
Cheshire
I have a 3/4 inch Dual Control Thermostatic shower valve - Victorian style. No Hot water coming through. Was working fine until now. Any ideas as to how this can be rectified? Help greatly appreciated.
may be the thermostatic cartridge has failed
are there any filters built into the shower inlets? the hot side may be scaled up/blocked up?
is there a valve/gate valve on the hot supply? is this fully open?
Thanks for the response, No filters built in as far as i am aware. Even at the valve inlet this is cold? How do you go about inspecting the valve inlet to see if it is fully open and is it easy to dis-assemble the unit? Once again thanks
