It may not be rotating. Has it got a big screw in the end? if it has take it out and see if the shaft is rotating. If it is not, then try turning it with a screwdriver.
Trouble is, the pump is at the back bottom of the boiler so I can't access it very well. I would have thought even a leaking pump would pump out some hot water?
