Hi ppl.. we have a central heating and hot water system that is completely nuts....
consists of cold water tank,,hot water tank,,gas boiler....
it uses a Drayton Lifestyle LP241 programer,, we just cant get how this stuff works....
The main problem is we dont get any hot water at all unless this is on,,i.e i can run the hot water tap all day long without a drop off heat unless its on at the timer.....
Same with the GAS central heating its not on unless its either timed or on at the programmer......
The boiler is one for central heating ONLY as i looked it up on the net,,, but when you put the hot water setting on, on at the programmer,,THE BOILER fires up,,i have had an email from the manufacturers of the boiler and they say the boiler does not heat water!!!!
So now yer askin why have a got a hot water tank??? i dont know!!! if by unknown methods the central heatng boiler heats water?? What does the hot water tank do?????
The main concern out of this is,, the electricity cost!!! were getting billed horredous amounts,,with only basic appliances that are good working order... so this is the only thing that must be eating the leccy...
