Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
after bleeding radiators - pipes very hot - since then no hot water when switch is on "hot water" (hot water only when central heating & water switch is on)
PLEASE HELP
Fair enough, that's the pump sorted, but on the pipes near it is something that controls the water going to the cylinder or to the radiators. There may be two valves. The valve is often (not always) the problem.
