No Water in balancing valve/manifold?
25 May 2013
Liverpool
Hello:
I have two axios manifolds. On one, I can see that water is sitting in the balancing valves (there are about 10 of them, which look like glass test tubes, sitting on red plastic rings. Of the 10, 2 do not have water visible inside them, while others have water at different levels inside them.
On the 2nd manifold, none of the glass valves have water inside them. Also, on this manifold, the 'flow' pipe is red hot, but the 'return' pipe is not at all warm (unlike the 1st manifold which has a pretty warm return pipe from the manifold). I have been bleeding the air out of both.
Any comments?
