When the central heating is On (pump running, room stat calling) the raditor in my bedroom makes weird noises, clicking/tapping, etc. These did not happen before. Also in the airing cupboard where the pipe runs up from the boiler downstairs, it is similar. Could this be scale in the system (system is open vented and over 20 years old). Would a boiler silencer (X200??) be worth a go?
I have checked and no pipes are touching the floor/walls to cause these sounds. Also the pump seems fine when I touch it and can hear its impeller spinning. I must also add that the radiators and hot water (cylimder) are all OK, it's just the noises.
Boiler: Potterton Flamingo II
Pump: Grundfos 15-50 (red casing)
3 port motorised valve (Honeywell V4073A)
Room Stat ACL Drayton
Cyl Stat ACL Drayton
F and E tank in loft
