noisy pipes
23 Nov 2005
Newcastle upon Tyne
hi all as some of you may know ive just had a vaillent 824 fitted working fine thing is when ever i open any tap hot cold, kitchen and bathroom there is a knocking in the pipes. Even happens when toilet is flushed. It seems more pronounced when the hot tap is operated.
your help is much appriciated
Sounds like water slam,
Change the wash mac taps too integral none returns and check pipes where clipped down when new boiler was fitted
thing is it was the boiler was a 1 for 1 swap and it happens when i run the cold taps and thats a direct feed from the mains. any ideas
what do you mean wash mac taps?
what do you think it could be like i say nothing has changed apart from the boiler and the cold tap goes no where near the boiler?
Then clutching at staws, ther is a dead leg on the water pipes somewhere that wasnt apparant with the old boiler.
I agree with craig on this. When the cold tap etc is turned on get someone to look at the display on the boiler. Does the tap symbol flash on for a couple of seconds.
If it does then a dead leg has been proved. If not keep looking.
