noisy pump after cleaning the CH
7 Jan 2005
I have Keston boiler with pressurized CH system. After I cleaned the CH with Fernox Restorer and flushed it then added Fernox Protector, my pump (Grundfos) seemed to get a bit noisier than before (lauder humming noise). I've bled the system several times and it doesn't seem that there is air in it. I've set the pressure to 1.4-1.6 when hot. Any ideas what may cause the pump to be noisier and how to fix it?
probably just spinning faster, what speed is it set on? and for how may rads
It is set on III for 13 rads but it was on III before when it was not so noisy. I've bled the pump as well when I bled the CH. BTW I've red in some of the previous discussions that if the pump is positioned vertical (like mine) it doesn't have to be bled, but I bled dit anyway. Also i have auto Air vent next to the pump but when i push it there is no air just a pressurized water comes out.
