- Joined
- 18 Nov 2003
- Messages
- 2
- Reaction score
- 0
- Country
I've recently switched over from warm air to a wet system (Worcester Bosch Junior 28i combi, 8 rads (3 TRV)). The installation went OK. However, when the system was commissioned there was what I considered to be an excessive whine (sounds like the next door neighbour constantly hoovering) coming from the boiler, which travels throughout the system. It transpires that the noise is being caused by the pump.
A WB engineer was called out, who replaced the pump. However, this made no difference whatsoever, so the engineer turned the pump down to its lowest setting, and arranged for their technical bod to come out. Although the lower setting got rid of the noise the pump was now unable to circulate the water fully round the system and some radiators were only luke warm.
The technical bod came out, replaced the pump again, checked over the boiler, and basically said there was nothing more that they could do.
Although it appears that the noise has reduced since the third pump was fitted, I'm not sure if it actually has or if I've just got used to the noise.
Has anybody else experienced similar problems?
Any ideas what's causing this noise?
Looking forward to your posts.
Best regards
Martin
Best regards
Martin
