Not a tumble drier fire! So the American says!
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
They say it was not the tumble drier but why were experts brought from America do we not have any experts, or did they need some one to say what they wanted to hear?
BBC said:
He added that arcing damage found in the overhead light fitting would not have occurred if the fire began in the dryer because that would have tripped the power and prevented such damage occurring in the light.
Well if wired as normal so lighting and power is not supplied from same RCD in any one room how would that work?
Daily Post said:
On Wednesday Garry Lloyd Jones, 50, who lived with the two men, told the hearing he saw flames coming out of the tumble dryer before he escaped the blaze.
That does not seem to point to light fitting or iron.
BBC said:
Dr Morrison said earlier he could not rule out the possibility of a spontaneous fire beginning in a pile of towels which were outside the dryer.
Daily Post said:
Mr Latack, who travelled from Michigan in America to attend the inquest, said he believed the fire had been caused by the spontaneous combustion of towels in the dryer.
It would seem the towels were able to leave the dryer by themselves and pile themselves up? There are other reports but reading them it does seem the American really has much idea of British wiring practice. There are comments about towels
ITV said:
He said he looked into the utility room of the flat and saw the tumble dryer with the machine door open and some towels from the restaurant hanging out of it. + He said he looked into the utility room of the flat and saw the tumble dryer with the machine door open and some towels from the restaurant hanging out of it.
I would say it seems very unlikely that a drier switched off with the doors open could cause a fire, however the news reports should help us prevent it happening again. But these reports seem to tell us nothing other than the manufacturer is trying every way he can to get out of it.
One posibility is the lint chamber was full of lint and there was a small area of the lint smoldering from when the drier had been used. That could smoulder for many hours before starting to burn with flames.
Is the manufacturer of the machine part of an American group whose lawyers are worried about large sums of maoney being paid if it is a fault in the machine of it's design ?
The article is obsessed with 'arcing' being the cause. While such things can happen, they are far more common with USA wiring, where impedances are typically high and fault currents low,. permitting arcing between conductors or at breaks in conductors. Partly why they are also obsessed with fitting arc fault detection devices to everything.
Arc faults are far less common here due to typically low impedances and high fault levels, resulting in most faults being cleared by the fuse/circuit breaker before any fire can occur.
It also mentions the dryer timer in the off position - so what? Has the person not considered a faulty timer or the smouldering issue as suggested by BG above?
Speculation veering into total fantasy.
Haystacks can spontaneiusly catch fire if the hay was slightly damp when stacked. So maybe a very very very large stack of slightly damp towels might self ignite. Only the stack would be far to large to fit into a house..........
oily or greasy cloths can self-ignite if tightly packed.
but if they'd been washed and dried? How much oil was on them?
If you follow the link I posted above you'll see that that increases the risk if any traces of oil remain. I have seen quite a few safety bulletins on this issue through my work.
I've seen oily rags smouldering when I opened a painters cupboard. They had been stuffed away unwashed.
Indeed, it's one of the warnings when using things like Danish Oil which is exothermic as it cures. If soaked rags (a cloth is the normal method of application) are then "scrunched up", the exothermic reaction may increase the temperature to the point where either the oil or cloth starts burning.
But it's hard to see how normal domestic towels, after a wash (who doesn't add extra detergent to a really dirty load ?), could have enough oil in them to do that.
Please explain.
A 1.2kW load on a 120v system would be 10 amps and 12 ohms.
A 1.2kW load on a 240v system would be 5 amps and 48 ohms.
It would seem impedances are somewhat lower in the USA and and fault currents higher.
The towels were from a restaurant apparently? More likely to have oil or grease on them, it also would depend on the quantity?
DS
