Sorry about the detailed intro but I'd welcome some suggestions if that's okay.
My Ideal Concorde CX 240P (Propane) gives off a loud 'pop' every time it shuts down. It's been doing it for a long time but now seems to be getting worse. Frequently the popping blows out the pilot light which is really annoying, especially as we run a B&B and guests complain when the heating isn't coming through.
Legally I have to have an annual inspection from a qualified engineer and this year when he came he took the front off the combustion chamber to have a look. Without the front on the flame shut down perfectly but as soon as he put the front on it started popping again when it went out. Fortunately, though it's quite a bang the engineer said it wasn't dangerous.
He tested the pressure which was okay, and a visual inspection of the burners showed nothing wrong so he suggested, as a long shot, that it might be a fault with the gas control valve not cutting off cleanly. He told me that if I could track one down he'd be prepared to come and fit a new control valve but he didn't want to go to the expense of buying one, only to find it hadn't cured the problem. I've searched online but unfortunately the valve (V4400D 1011) is now discontinued and Honeywell aren't very forthcoming about an alternative.
On another forum somebody suggested I should get a new boiler but I'd prefer to investigate possible fixes first.
1) Has anybody any other suggestions as to what might be causing the popping? If it works okay with the front off might that mean that there's either too much LPG or not enough air when the front is on? Might the jets have become enlarged? It's quite an old boiler and they've never been replaced.
2) Since I can't buy a new gas control valve can I get the solenoids replaced and if so where would I buy them? Would they be the same solenoids as those on a V4400C, which looks an identical valve but apparently is for mains gas only?
Thanks for your help.
BK
BK
