I have the following board that is switched on only during the winter and is used to switch on 3 night storage heaters.
View media item 50092
The rest of the house uses a teleswitch and so is using off peak between 12.30 - 8.30.
I wanted to add three seperate thermostats (suitable rated etc) that will only switch on the night storage heaters if the temp drops below a certain temperature. The property is a holiday rental so it is difficult to switch the heaters on/off when it is warmer etc.
I had assumed that the three wires coming out of the top would go to each of the three heaters.... however, one of them appears to be constantly live (only tested using a stud/ vold detector etc) even if I remove the fuses and this is during the daytime? The wire disappears off somewhere that I can't trace....
Any suggestions as to what this might be for? I am assuming it doesnt go to the heater I thought it did - that I was going to attach a thermostat to....
Thanks.
Thanks.
