Hi
I have a problem with my boiler. I kind of think its the photo cell but not sure. The Boiler will start on the button. Will run for 20sec then cut out. If I then press the reset button it will then continue till the water is a temp then will not start again.
We ran out of oil and had the tank filled with 1000ltrs (boy did that hurt). This was when the problems started. i've cleaned the nozzle checked the in line filter and striped the pump and put it all back together. i've checked for air in the system but still the same Symptoms. runs 20 sec stops restart runs till hot stops.
Any Ideas would be great
