I have an oil fired cooker/boiler with twin burners. When using cooker only some heat goes to the boiler. The pump is controlled by the boiler temperature and switches at around 50c. If this is driving a Y plan system the with neither DHW or CH selected, then the 3 way valve would default to DHW and put the excess heat to the water. However, I have an S plan system and the hot water valve is switched by the controller via the cylinder stat, and switches on the boiler via its auxiliary contacts. The surplus heat cannot therefore go the DHW. In order to remedy this I propose to use the pump supply to switch the DHW valve, and when DHW is selected send the power to the boiler burner via the cylinder stat rather than the valve contacts. Does this appear OK.
