My boiler has just started giving the following problem.
After a cycle of running ok the burner switches off at the 'low' setting,on the front panel setting switch,as normal.The problem is that when it comes to restart(when the temperature has dropped below the 'low'setting)a buzzing noise is heard from the burner region and after a few seconds the control box locks out with the orange light on.I have found however that i can make it fire up again,during the buzzing,if I quickly turn the front panel switch on and off a few times before the control box goes into lock out mode otherwise I have to wait for the normal 1 minute restart period.
I have recently fitted a new control box and light sensor and when it does run every thing seems to work fine.
It seems that another component is acting up but which one ?
I would appreciate any advice on the subject because its got me baffled.
