Hi, I noticed my heating wasnt working this morning. After quick investigation i found that the water pump on the boiler was working fine but the oil pump runs for about 10 secs then cuts out and you have to press the reset button to restart.
I striped the system down to see if the jet was blocked but it seems to be working fine apart from no oil getting to the jet.
I traced the fault back to the oil pump, the pump seems to be running, oil is going into the pump but none is coming out.
I took this picture of the pump to try and explain better.
www.zordey.com/pics/oilpump1.jpg
Oil flows fine in from the pipe at the bottom but none comes out from the L shaped pipe at the top right. Loosening the L shaped pipe slightly lets oil leak out so the blockage seems to be inside that pipe.
Does anyone have any suggestions what is wrong? Also does anyone know what the we electronic part is just under the red plate, looks to be a heater of some sort???
Thanks.
Edit:= Picture doesnt seem to work please click on link.
Thanks.
