Old Hot water Cylinder
15 Jan 2007
Cheshire
We have a (very) old central heating system installed with a conventional floor mounted boiler and hot water storage tank in an airing cupboard.
It is undoubtedly very inefficient but it works well and has caused no problems (apart form a replacement pump) in the 15 years we have been at the house.
I have no intention of replacing the boiler until I have to, but would like to make the current set up as efficient as I can.
The current Hot water storage is a copper cylinder with an insulating jacket around it. I wondered what the advantages would be of replacing the cylinder with a more modern one with moulded insulation? Would any savings result from doing this once I factor in the cost of supplying and fitting the new cylinder?
I'd wait until it starts leaking.....just keep it well lagged with its jacket and any blankets etc that keep the heat in.
I wouldn't disturb it in any way, either!
John :)
A more modern cylinder will heat up much faster. However it will cost hundreds of pounds. You can have one or two electric immersion heaters fitted to heat it when your boiler is out of action, or if you get solar panels. You can also get a bigger one if you want.
Is your old one pumped or gravity feed from boiler? Pumped is also faster and more efficient. If pumped there will (should) be a thermostat strapped to the side of the cylinder.
You can add a second red jacket to reduce heat loss. Also put Climaflex or similar on all hot pipes.
Yes, if you disturb the old cylinder or its pipes, it may well start to leak.
Keep looking under it for damp or woodlice.
John :)
Thanks, That is just the sort of advice I was hoping for - do nothing :mrgreen:
It is a pumped system, we have one pump for the HW and another for the CH (and a cylinder thermostat)
