Old plastic waste pipe
19 Apr 2006
My cast iron soil stack has 2 holes in it - one accepts 32mm pipe and the other 40mm.
The waste pipe is joined to the soil stack by a compression-type fixing.
I have bought some new waste pipe but there is a problem - the pipe can be pulled-out of the soil stack holes.
On inspecting the old waste pipe there is a flange where it joints the soil stack which prevents it being pulled-out of the compression fitting.
Does anyone know where I can buy an equivalent to the old pipe?
Many thanks
The "flange" must be the original "olive"(compression ring) on the pipe ..can you post a pic. :?:
Why not just join the new pipe to a short stub of the old pipe using a compression (multi-fit) fitting?
Or update the whole stack adding a nice rodding eye in the bottom of the stack - unless it goes straight into a man'ol
