We are at our wits end!
We have one cold radiator upstairs and one downstairs. When they are bled, they heat up but as soon as you shut the bleed valve, the radiators get cold again.
The floorboards have been pulled up and the pipes leading to the cold rad downstairs are hot but above the floorboards they are cold. The whole system has been drained down and the water was quite clear (no evidence of sludge).
We haven't lifted the upstairs boards up yet to see if the same is happening in our bedroom.
Downstairs, the rads either side of the cold one are both warm.
We have just replaced the radiator downstairs with a new one , thinking all our problems would disappear but no such luck, the new (expensive) radiator is still cold like the old one was!
One suggestion has been that the flow and return pipes may have been mixed up when the CH was installed (6 yrs ago approx.) Does this sound feasible?
Any suggestions out there? (Ariston combi-boiler - 11 radiators on the loop, 5 of these are doubles).
Thanks.
Thanks.
