- Joined
- 13 Feb 2022
- Messages
- 11
- Reaction score
- 0
- Country
Hi all
I am hoping to get a little help! and clear some things up.
We have recently had an Extension built (mostly built by myself, signed off and all!) and now comes the time to tackle some of the rest of the downstairs work.
This weekend we gutted the livingroom 4M x 4M in size, back to brick and all, but now we also need to replace the suspended timber floor. Some of the joists are rotted and sheared, some have just dropped.
the cause of the rott was mostly due to the cavity wall being filled/bridged 300mm above the DPC with crap, broken down snots, blocked vents, lack of airflow and exterior ground level above DPC. amazingly the joists that were rotted were only rotten where they went into the wall!
All these have been corrected, it's now time to replace the floor, and i am having doubts... this added venting presents the obvious problem of making the floor colder and the room was never great anyway. Our kitchen has had a complete new floor build up including UFH in the screed, and now i walk into this cold room!
I am not planning on going this far again, maybe something in the middle? i want to stick to radiators in here, so i have options.. hopefully someone could cast a few
Easy option first
i could drop in 100mm Celotex between the joists as i go along fitting joists, maybe a return on the underside of the joist to keep them in place long term and also foam any slight gaps.. wrap the ends of the joists into the wall with DPC/visqueen and seal round with joint sealer. i am in favor of this due to cost and speed!
2nd option.
Fill with EPS and concrete!
the oversite is around 300-390mm deep to finished floor level. it would give me room to drop in a concrete base, lots of EPS and a screeded floor. the biggy here is the cost and also, are there any implications in doing this? its dry down there and does not seem to pool up with water from what i can see. the screed we had pumped into our kitchen was great, perfect finish and fast. however this is where the cost would bump up!
Thoughts?
Easy option first
2nd option.
Thoughts?
