outdoor lighting flex
3 Mar 2006
London
Hi i need to run some cable at high level outdoors about a 3 metre run ,for an outside light was thinking of using plastic conduit and t+e. but would rather use a bit of flex clipped to wall. any ideas which cable i should use ?
Flex in conduit is easier to terminate at the light than T&E. You could use black hituf straight to the light.
If you use PVC conduit, use black outside as its UV resistant.
