Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Some PIRs have a manual override which allows the light to stay on. Check the instructions for how to disable the override. Otherwise try turning off the power for a while and then turning on again. Some lights have a test cycle for a few minutes, so give it time to turn off on its own.
Check the time isn't set to maximum. The PIR will operate when powered up initially as it tests itself. If the time is set to maximum when it is first turned on it will stay on for hours before it times out.
