S
SplanK
We have had our kitchen done, and I thought I would get 2 outside lights fitted so we could hide the cables in the wall and have them switchable so we can isolate them independently as and when needed.
So, bought 2x basic Wickes lights, simple PIR controlled units with 2 terminals, one live (which is switched by the PIR) and one neutral...
Gave the instructions to the sparky in how we wanted them fitting.
He completed the work last week, and I have just got back from Stratford and tested them out. I will simply refer to the lights as left and right with the switched wired as such. There is a single spur coming from the light ring main into a double switch socket, with 2 cables going out, one to each light
Left switch off = Left light on PIR control
Left switch on = Left light on (no PIR control)
Right switch off = Right light off
Right switch on = Right light on (no PIR control)
I am a touch confused, this is not what we asked for, and how the heck has he got the lights to function the way he has?! Due to a number of reasons, we will not be getting that sparky back (he was sub contracted by our kitchen fitter). I will be asking for somebody else to come and fix it, but just thought I would try and get my head around it....
I am not sure if the right light has a faulty PIR unit, or if the wiring prevents current getting to it (its wet outside so thought taking a multi meter to it was a bad idea!)
This is the rear of the double switch socket...
