Hi All
Sorry about the mind numbingly basic question but i just can't find an answer in old posts:
when talking about cable sizes in a domestic situation, is using larger cable than required acceptable?
for example if you disconnect an appliance that was the only thing on a circuit and is wired with say 4mm cable and wish to replace it with a socket that would normally only require 2.5mm, can you make use of the existing cable or do you have to run new?
