Hello all
I have a problem with my boiler it works fine with the heating on but when hot water is called for it run for around ten seconds then them temp gauge shoots from 60 - 90 degrees very quickly then trips out and has to be reset with the red button. i am not sure but if there is some kind of blockage either in the heat exchanger or the divertor
. any ideas
chris
chris
