    Dismiss Notice
Painting MDF Alcove and Wardrobe Units
Discussion in 'Decorating and Painting' started by Johnsmith, 27 Jun 2006.
  1. Johnsmith
    Johnsmith
    28 Nov 2004
    74
    Thanks Received:
    2
    Country:
    Hi, I'm having a carpenter build some MDF Alcove and Wardrobe Units for me (you know the type of thing - every Victorian or similar house in the whole of the UK seems to have them - apart from mine). And I get the lucky job of painting them this weekend (not at 4pm on Saturday, though ;) ) and probably next too.
    Does anyone have any tips or come across a useful website explaining which paint to use, whether brush or roller is best and the best method for painting?
    Thanks very much in advance.
  2. Sponsored Links
  3. Zampa
    Zampa
    14 Mar 2005
    5,778
    Thanks Received:
    30
    Country:
    I would go for a oil based primer...slightly thinned out first...water based primers can raise the grain of some types of MDF.
    Given that the surface is very flat, ut wil show up any blemishes...so a foam radiator roller is great for getitng a nice even finish.
    Rub down between each coat with fine wet an dry paper or 120 grade aluminium oxide paper.
    You can use anything really as a finish coat..but bear in mind shiny surfaces can sometimes look a bit cheap looking..
  4. Johnsmith
    Johnsmith
    28 Nov 2004
    74
    Thanks Received:
    2
    Country:
    Any idea as to the order in which I do the panels? I assume I don't just approach it in bish-bash-bosh style?
  5. Zampa
    Zampa
    14 Mar 2005
    5,778
    Thanks Received:
    30
    Country:
    Do the panels first..but make sure you dont over brush onto the face of the doors themselves...keep a bit of rag at hand to wipe the access off.
  6. Johnsmith
    Johnsmith
    28 Nov 2004
    74
    Thanks Received:
    2
    Country:
    Now, at the risk of sounding a bit gormless:
    1. How do I think down oil based primer? Water??
    2. Can you recommend anything (nothing fancy - perhaps just something from the screwfix catalogue?) on the primer front
    3. How about a paint that I could use?
    4. I assume I dont need to sand after the primer coat? Won't it just be absorbed?
    5. Finally, seeing as I cant find my trusted Collins DIY manual anymore, have you seen any literature that I cvan have handy on the order in which to do the panels? I remember when I penated my sashes that they were really complicated?
    Cheers, much appreacited.
  7. Zampa
    Zampa
    14 Mar 2005
    5,778
    Thanks Received:
    30
    Country:
    1. White spirit
    2. Thinned out undercoat or oil based wood primer
    3. ?
    4. No..you must sand after the primer...this is crucial to flatten any furing
    5. Its difficult to say mate without seeing the doors/panels themselves..but as a general rule...panels, first..then work you way downpainting each piece as if it was constructed from seperate parts...like an old fashioned door.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
