painting on new plastered walls.
25 Feb 2004
i have just have had my ceiling and walls plastered,the ceiling with two coats as it had a light artex.the walls where skimmed just for a smooth finish.both where done a couple of days ago,the walls are drying quick,the ceiling is nearly there.
however i have booked a new floor to be fitted in 8 days,and i would rather have the painting finished by then.
any ideas on the best way to paint over the fresh plaster.
Single coat of unibond followed by a whitewash with matt is what I'd do prior to applying the paint proper. :)
Is it safe to use unibond PVA on a new wall? someone suggested on this site that this May cause condensation.
I don't know if that’s correct - has anybody experienced this?
Others say to use Mist coat, basically Emulsion paint mixed with water but this doesn’t work 100% you'd still get bubble on the wall.
Thanks,
Miah
Or is it best and safe to use Dulux plaster sealer?
I would use acrylic sealer and two top coats,should dry very quick between coats,I like to use dulux as I think their paints are worth the extra money,they do last longer and wear much better.
