Kitchen and bathroom paint have similar properties that you find in Silk paint.
If the K/B paint has been up for a few years and you want to change it to matt for example,(same with silk) you would give the walls a good rub down for the matt to adhere too.
If you have made a booboo, and your K/B paint is fairly recent and you want to go to matt, you might have problem.
There is a trick as such and it does work buy some soft sheen paint, and put that on the walls, after you have done your prep of course, then you can go with matt, and you shouldnt have any comebacks.
Even oilbase undercoat works, but you would still have to get some of the sheen off, I know the soft sheen does work, as I got this tip many years ago, and I scoffed, thinking, Yeah Right, so I gave it a go, and it does the trick beautifully, since then I have done it many times, but must admit, have used the undercoat too.
