Permanently on lights
MIM
27 Mar 2005
Good morning all, and happy Easter!
I'm replacing a ceiling light with a new unit which came with instructions of the chocolate fireguard variety.
The light is the last one in the loop, so I only have two cables coming in - one from the previous light, one from the switch.
The lighting unit itself has four connector blocks - marked L, N and E and one 'empty'.
I have connected the two lives and the neutral from the switch to the 'L' block, the other neutral to the 'N' and the two earths to the 'E', and the light works. Problem is, it won't switch off.
The other problem I have is that the light unit itself does not have convenient blue and brown wires on the other side of the connector blocks. It appears to have a number of wires covered in a braided material, which go to the bulbs themselves (via what I can only describe as plastic nipples).
Based on suggestions I found on other threads, I've tried taking the red live wires and connecting them (individually) to the blank connector block, but this hasn't worked.
I'm loathed to dismantle the braided wires of the light unit, to try and figure out what is what, so I'm pretty desperate for suggestions (especially seeing as in my true style, I have managed to have my balls-up on a bank holiday weekend... :cry: .
Cheers
Iain
easy, im an electrician see this all the time.
if you have two reds and two blacks and two earth cables:-
two reds in spare terminal block
two earths in earth block
black from switch into L terminal
black from feed into N terminal
Job done
sorry should have explained the black cable from the switch is actually a switched live cable ( it becomes live when you turn on the switch ) you should realy identify it with red tape to show it is a live cable
Absolutely superb!
Many thanks (have an extra choccy egg!)
Thinking about it, it was obvious...
The two live wires go....as far away from the block marked 'live' as they can go... ;)
Job done
This will work perfectly but isn't it more usual to put the two lives in the block marked L? Black from the switch and brown from the light then go in the 'spare' block. Hint: count the number of terminal holes in the blocks. If the spare has only two, where would you connect a live feed to the next light if this was not last in the line?
It is most common to see normal 'choc block' type terminal blocks. These have one terminal, and you can put as many cables as will fit.
The L on light fittings is for the Sw live for the lamps. The 'spare' terminal is called the 'loop' for looping the constant live between fittings.
You've got me thinking now. I'll have to double check. Thanks for that.
