HELP !
The problem is that I have hot water in the expansion tank in the loft. It's steaming and wetting the felt and timber in the roof.
I have an open vented central heating system with pumped hot water.
The boiler is an oil fired Gemini boiler located in a utility room.
The heating and water are pumped by a grundfos UPS pump sited in a cupboard next to the boiler.
The house is predominantly single storey with just three rads on the first floor.
The expansion tank is located in the eaves of the loftspace above the single storey part of the house and is only around 1M above the highest radiator.
After reading back over some of the similar problems posted here i've done some investigation.
Initially when either the hot water or heating were on individually everything was fine. If both were on together water was pumping over the expansion pipe into the tank.
I turned the setting down on the pump from 3 to 2 which has stopped this from happening. The level in the tank looks 'normal' about 1/3 full.
However, if both the water and heating are on together i'm still getting hot water in the tank. Either the water or heating on its own isn't causing the problem.
Any ideas ?
Any ideas ?
