peugeot 106 radio removal
30 Jul 2006
My radio has stopped working in my Peugeot 106 (L reg).
The alarm light fitted to it was still flashing but the digital display and volume would not work.
So, I disconnected the battery and reconnected it.
Now the alarm light doesn't even work.
Next thing, I checked all the fuses with a multimeter and they all seem intact.
So, now I'd like to remove the radio. I saw some mechanics do this once before when they had to get the code for the radio and I know I'll need some flat keys to do it, but not sure which kind.
I've seen some on eBay - are these standard?
http://cgi.ebay.co.uk/CAR-STEREO-RE...oryZ1498QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Any other advice / recommendations for what to do/check?
Actually, thinking about it, they might have used some sort of plastic down the sides to release the latches.
Any substitutes I could use instead of that?
I have the code from the previous time when the local Peugeot dealer got it for me (for about £15...more like £25 now).
I'm pretty sure it's a Clarion radio but of course, it doesn't say the model or make on it...just Peugeot.
Not sure which of these to get plus they look quite pricey:
http://www.caraudioplus.co.uk/Tools/Car_Radio_Removal_Tools/Clarion_Radio_Removal_Tool_(Set_1)
http://www.caraudioplus.co.uk/Tools/Car_Radio_Removal_Tools/Clarion_Radio_Tool_(Set_2)
http://www.caraudioplus.co.uk/Tools/Car_Radio_Removal_Tools/Peugeot_Radio_Removal_Tool
Is there no way I can do this using a screwdriver or some homemade tools?
A new radio probably comes in at around £16 on eBay so I'm keen to keep this cheap as it's a fairly old car already.
If they have a round hole in the radio then you can normally use a couple of allan keys to press the release catches down then pull the radio out or you could use a couple of thin brazing/welding rods bent into a U-shape
Some peugeot radios only have a single round hole so just need one rod either side
