If wanting the visible pipe which connects to a radiator (the rad has not yet been installed) to have a nickel-finish, is it better to
a) connect up the rad with plastic/copper 15mm pipe, but with a nickel-finish shroud placed over the visible pipe before connection
b) connect the rad with 15mm nickel-finish copper pipe and then connect under the floorboards to the plastic/copper pipes.
Thanks.
Thanks.
