Hello: I installed a chrome towel rail on a breezeblock and plaster internal wall. Pipes chased and tunnelled through wall from void in floor and emerge from wall to reach the radiator valves two inches or so away (coming straight out of the floor is not an option). All pipes are copper 15mm (wrapped in that sticky tape) except last stub to the radiator which is chrome. All joints are soldered except last elbow inside the wall to the chrome pipe is compression. A plumber who saw the work said I should not have compression joints buried in plaster because stresses from future maintenance of radiator could cause leaks. He said use solder elbow or plastic push fit. Is this good advice and worth redoing the work? Questions:
a) If I solder, I'll need to have other end of pipe in the radiator valve for alignment purposes. Won't heat 2 inches away damage compression fitting on the valve or the valve itself? Obviously won't use chrome for that pipe.
b) if use plastic elbow, won't stresses of future maintenance in 15 years cause potential leak of O ring anyway? By the way, how do you safely bury plastic couplers in plaster?
Thank you in advance!
