Plastic fence advice
16 Jul 2004
Hello there
I am planning on putting up a plastic fence (I think that's the right term - the stuff I was going to buy is called climbing support). I think it looks fairly straightforward - i.e. metal posts equal distance apart and use ties to put the fence to the posts.
However, I am new at this kind of thing and would really appreciate any advice anyone can give with this type of fencing - if you've done it and have any 'this is what I would do if I did it again' tips!!
Thanks very much
Katro
The only problem I can see the plastic sheeting will sag if it's not tight and depending how far the posts are apart. Might be idea to use heavy duty garden wire as well (green type) top, middle & bottom. Put the wire in & out of every other hole or maybe more then tighten it on each end.Twist the wire with a plier.
That's really good advice, thanks very much.
Fingers crossed!
