Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Is the fitting an elbow for a rad?
If so, you can't really avoid setting it in.
If it's a joint in a run, then use a coil of plastic so you avoid joints in plaster.
