plastic to copper
5 Dec 2013
Hi, can i join plastic to copper on my central heating system
Are you
1. Adding the copper to an existing plastic installation
2. Adding the plastic to an existing copper installation
If 1 ideally you need to determine the manufacture of the plastic pipe and use a fitting and insert of the same manufacturer to preserve the warranty. Or use a compression fitting (with insert) and copper olive and PTFE tape if needed.
If 2 you can cut the copper with a pipe slice and connect the plastic push fit fitting directly onto the copper tube (as long as it is to BS and not chrome plated)
