Hey everyone
With the cold weather recently my central heating stopped working last night, after some investigation tonight it seems the pipes running from the boiler to the house have frozen and one has split, now whoever installed this boiler was a total cowboy, the pipes are ran about a foot from the floor with nothing holding them in place apart from the plastic fittings. They run about 3 meters from the boiler to the house, then 2 meters up and into the floorboards upstairs, he has used copper outside with plastic fittings inside, all 22mm which I think is standard.
Also the twin and earth power cable is just ran along the foor and not protected or secured by anything!
The lagging is very patchy and bits have been missed, I think this is where the problem is.
I only moved into the house at the start of the year but I think this boiler has been fitted for over 10 years now.
Sorry for the lengthly post but just want to confirm a few things.
I am going to replace pipe work coming from the boiler house with plastic, so the first 1-2 meters inside the boiler house are still copper, I am going to use push fit joints and fit a couple of extra elbows so I can run it along the ground properly and secure it, then lag and box the pipes in, also I am going to redo the wiring and run it inside some conduit and get it secured down somewhere, problem is where it goes into the house it has just been cemented in place (grrr!)
If anyone can provide with some help on this or advice it would be most appreciated.
Thank you
David
Thank you
David
