Hi all
please can someone help me,
my son has just bought a house which was built in 1900, and has two loft rooms as standard,
the house was survey and all was mentioned was the electrics may need updating, small damp issue and house suffered from subsidence in the past but this has now stopped.
but since picking the key, and we have gone into the loft room and noticed two vertical cracks, starting from the centre of the wall and going down, behind the skirting board,
i dont think its come all the way down as the room below has no crack but then again the wall is wallpapered.
please look at the pics and advice me if it is a serious thing or just a plastering job?
also can i make an issue with the bank who done the survey?
View media item 50746 View media item 50747 View media item 50748
thankyou for your help.
i have ripped some of the wallpaer off so you can see crack, i have pulled out some of the loose pieces from the wall, it looks like plasterboard but behind there you can see bricks and its looks as the brick is cracked.
