Sorry for what must be very simple question.
The plumbing under our sink has a sink/washing appliance trap with a waste hose connection point for 2 appliances. We are only using one of these at the moment. When the appliance runs some foam & waste is ejected via the unused connection, which is a pain.
I've looked at Screwfix, Wickes etc but I can't see an end plug that I can replace the unused 32mm hose connection with. A 32mm push fit doesn't fit (as it is exactly the same size as the fitting - I've tried) and 40mm is clearly too big.
What should get instead to block off the unused connection?
Thanks in advance.
Thanks in advance.
