Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a stud partition in my bathroom that I need to fix a wc and wall hung basin vanity to. I need to reinforce between the studs with ply to give a good fixing. What thickness ply is required for this use?
9mm
12mm
18mm
stick a couple cls off cuts in the right place. ply is dear. no need for the bog . the tile is more than strong enough to support the cistern if you want to screw it. I don’t even screw cisterns , 2 blobs of silicone.
