- Joined
- 22 Oct 2007
- Messages
- 131
- Reaction score
- 0
- Country
I fitted a garden tap last month as I got fed up of the adaptor slipping on the kitchen tap and spraying water over the room. (and I fitted a new kitchen and the new tap won't take a hose)
We have a downstairs bathroom with good water pressure from loft tank, I used push fit fittings to tee off the bathroom cold water pipe under the sink, used a stop valve and approx 400mm of poly pipe to take the pipe behind the bath and then a 90 degree connector to fit onto the rear of the copper pipe that feeds directly through the wall and into the wall plate to the tap.
Volume wise the flow is fine, but as soon as you attach a hose, even a short length, the lack of pressure is obvious. Point the hose at the sky and instead of getting my neighbours washing wet it struggles to rise a foot. If I turn the bathroom shower head upside down (fed directly off the taps) the spray will hit the ceiling.
I'm hoping someone is going to tell me there is something wrong rather than I should've taken the feed from the rising main!
