I have a Worcester Greenstar 30HE combi boiler.
I have tried to fit a new bath and found that the 22mm copper hot water pipe feeding it has a green sludge build-up inside it. I think this sludge and debris coming from it has caused the new tap, a ceramic disc type, to constantly drip.
I also find that the boiler can only supply enough hot water to feed one tap at a time, even though when fitted I told the supplier there were 3 bathrooms, one of which has a Aqualisa Quartz non-pumped shower.
I do not have either a cold storage tank or a hot water cylinder as all water feeds directly from the mains, via the boiler.
Can anyone suggest: -
a/ How do I clear the sludge from the pipes, and/or
b/ How do I increase the flow rate so that more than 1 hot tap can be fed at one time.
