Potterton Kingfisher 2 RS boiler
If it has gravity circs check f & e tank in loft is full as ballcock may be stuck in the closed position
Thanks for the reply
Checked the tanj and the ballcock is operational and the tank is full.Could the zone valve be part of the problem?
could well be, try turning on ch and then moving the lever on hw valve to see if heat goes to cylinder.
